Adrian
Member
Currently I am operating my Paramounts fed from the Submissive as a "passive" input and feeding Blumenstein 2.2 mini/max system (original minis + max subs). This works ok with the EROS as the necessary phono preamp and I get relatively good volume from my speakers - the submissive volume controls are at about "3/4" full volume setting for the maximum I will listen. However, when I run my CD (Cambridge Audio), I commonly have to run the submissive at full volume.
If I add the Beepre to the Paramounts, about how much lower than these volume settings can I expect for the same perceived volume?
I would like to have a little more volume "head room" and be able to achieve higher perceived volume levels.
What I don't want is to have too much gain into the Paramounts that will drive the volume controls of the Beepre to significantly less than "1/2".
(The more I read this the more I'm thinking I'm not explaining this well!)
