You would have to define what a "simple" comparison would be.Demsy said:Can I then conclude that no owner of the Beepre has ever done a simple A, B comparisson between the balanced and unbalanced output?
I should have been more specific, indeed. What I had in mind was comparing the sound between the outputs using power amp that has balanced and SE inputs.Caucasian Blackplate said:You would have to define what a "simple" comparison would be.
Doc, I have two systems and both have the balanced and SE option. The distance between the pre and the power amp is about 3m and for this I have to use a 4m long cable. I have compared the sound and the balanced is significantly better in this long run. I'm using unshielded Kimber balanced cables.Doc B. said:The single ended output will sound a tiny bit better - unless you have an amp that will only accept a balanced input. Then the balanced output will sound better.
If your amp has both SE and balanced inputs it may itself sound different from each input. You just have to smoke it and see.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
