Bee Pre - Low Voltage values
Horatio
Hi, just been through the resistance and voltage checks on my Bee Pre build... Unfortunately the figures don't look quite right:
Resistance check appears close with:
A4 and B1 looking low
A1 and B4 looking high
10 and 15 falling rather than rising
27, 32, 39 looking high at 0.9v but that may be within the margin of error as most my 0's for resistance were actually showing 0.4
Voltage check appears further out with:
T6, T11, C / D 3, C / D 7, C / D 9 all appearing on the low side
It feels like I may have made the same mistake on both sides...
When I did run some audio through it to a solid state amp it sounded muffled with a lot of the high end missing...
Anyway, any advice at this point would be much appreciated... I will likely be reworking all the solder points on the circuit boards later today...
Line Voltage: 248.5
Tubes: EH 300b
All tubes light up...
My kit was short the R3 143K 0.5 W metal film resistors for the regulator boards and I have substituted a pair of 100K 0.6W and 43K 0.6W (soldered in series) in place of each as an interim measure until I get a local replacement.
Resistance:
Terminal Manual BeePre
1 High dropping to 4 4.4
2 Greater than 100K (OL) 288k
3 0 0.4
4 5-6 with 300b in socket, * 5.6
5 0 0.4
6 more than 30k 49.9
7 470k 473
8 0 0.4
9 0 0.4
10 starts low, rises to 20K+ *** starts high and falls to 20k+ ***
11 more than 30K 50.4
12 470K 473
13 0 0.4
14 0 0.4
15 starts low, rises to 20K+ *** starts high and falls to 20k+ ***
16 starts high, drops to 4 4.6
17 greater than 100K (OL) 282k
18 0 0.4
19 5-6 with a 300b in socket, * 5.6
20 0 0.5
21 0 0.5
22 greater than 100K (OL) 282k
23 0 0.4
24 0 0.4
25 greater than 100K (OL) 100k+
26 0 0.4
27 0 0.9
28 0 0.5
29 * *
30 * *
31 * *
32 0 0.9
33 0 0.5
34 * *
35 * *
36 * *
37 0 0.5
38 0 0.5
39 0 0.9
40 greater than 100K (OL) 100k+
41 0 0.5
42 0 0.5
43 greater than 100K (OL) 100k+
44 0 0.4
45 0 0.5
46 greater than 100K (OL) 100k+
47 N/A N/A
48 stablise to 603 603
49 0 0.4
50 N/A N/A
51 stabilise to 603 604
A1 starts high, drops to 4 5.5
A2 greater than 100k (OL) 282
A3 varies with volume / balance 0 to 50 16.6k
A4 5-6 with 300b in socket 4.3
B1 5-6 with 300b in socket 4.4
B2 greater than 100k (OL) 280
B3 varies with volume / balance 0 to 50 16.3k
B4 starts high, drops to 4 5.5
C1 N/A N/A
C2 215 213
C3 OL 545
C4 greater than 100 greater
C5 greater than 100 greater
C6 N/A N/A
C7 more than 30k 49.3
C8 N/A N/A
C9 more than 30k 49.6
D1 N/A N/A
D2 215 215
D3 OL 545
D4 greater than 100 greater
D5 greater than 100 greater
D6 N/A N/A
D7 more than 30k 50k
D8 N/A N/A
D9 more than 30k 50k
Voltage:
1 5v 4.95v
2 90-110v 102
3 0v 0
4 9.85v 9.73
5 0v 0
6 146v 103v
7 0v 0
8 0v 0
9 0v 0
10 186v 189.8
11 146v 93.7
12 0v 0
13 0v 0
14 0v 0
15 186v 189.1
16 5v 4.95v
17 90-110v 91.5
18 0v 0
19 9.85v 9.75
20 0v 0
21 0v 0
22 213v 216
23 0v 0
24 0v 0
25 213v 216
26 0v 0
27 0v 0
28 0v 0
29 6.8v 6.8
30 6.8v 6.8
31 13.6v 13.6
32 0v 0
33 0v 0
34 13.6v 13.6
35 6.8v 6.8
36 6.8v 6.8
37 0v 0
38 0v 0
39 0v 0
40 213v 216
41 0v 0
42 0v 0
43 213v 215
44 0v 0
45 0v 0
46 213v 215
47 N/A 0
48 0v 0
49 0v 0
50 N/A 0
51 0v 0
A1 Risky Not Measured
A2 90-110v 98
A3 0v 0
A4 Risky Not Measured
B1 Risky Not Measured
B2 90-110v 91
B3 0v 0
B4 Risky Not Measured
C1 N/A
C2 0
C3 3.5-4.5v 0.75 measured on 20v setting
C4 N/A
C5 N/A
C6 N/A
C7 147v 101.1v
C8 N/A
C9 147v 100.4v
D1 N/A
D2 0 0
D3 3.5-4.5v 0.75 measured on 20v setting
D4 N/A
D5 N/A
D6 N/A
D7 147v 93.3v
D8 N/A
D9 147v 92.6v
Ignore the additional selector switch you see in the photos - that is not currently connected to anything and is a placeholder for a future upgrade to switch outputs...
Bill
PB, don't be ridiculous, the 431 socket is where I like to keep my PN2907 - there wouldn't be room for both!!!
Soldering iron once again heating up!!!
Thanks mate!
Bill
What do you know, it turns out the PN2907 likes its own socket much better and the 431 has settled right in now the squatter has been removed. All voltages bang on perfect and I now have a fully operational Bee Pre sitting warming in the corner of the room.
PB - I can't thank you enough for all your help today you have been an absolute star at diagnosing both my stupidity and the effect it has had on my kit!
Thanks again!!!
Bill
Hey, we're a team! I'll take credit for the circuit, but the layout (and the diagnostics in this thread) are PB's, and it would never have happened if Doc B hadn't kept pushing us all to try the 300B. He gets a long lease on the corner office for that!
