Attached is a sketch of my last mod of the Quickie low pass filter, using the Sowter 9063's as output trannies. They are spec'd at 24 dBu, with good low end response. I made sure not to give away any of the Quickie design in the sketch.
Bass volume is now just a tad shy, but bass quality seems much better, quicker, deeper and just more musical (I check this by turning of the Excite main amps and leaving the Paraglow bass amps on).
Two questions:
1. I'm totally in the dark whether it is a bad thing to load the transformer secondary with a value lower than its own impedance (but higher than its DCR).
2. Also, I am wondering if there is a way to increase Quickie gain, such as maybe a different plate choke or a C4S at higher voltage. I am redoing my phono pre PS and have access to clean HT. If not, can I just increase the input resistor to the Excite to pad it down a little?
Here are my calcs, though I'm sure there are some mistakes in it:
Stock Quickie output impedance 2k and gain 2.25 ( http://db.audioasylum.com/cgi/m.mpl?forum=bottlehead&n=138602).
With Hammond, it should now be 4.5 and output impedance should be 4K as per
(http://db.audioasylum.com/cgi/m.mpl?forum=bottlehead&n=138791)
Now it should be at 4K output impedance at 4.5 times gain.
Putting the 110 ohm DCR in parallel with the 500 ohm loading resistor gives 90.2 ohms (about 82%) , and the ratio of 500/600 ohms also gives 83%. So either way, reflected back to the primary is 82% of of the secondary's impedance, so the 10K should now be seen as 8200 ohms, about double the Quickie's 4K output resistance for max power. Is that right? It's real muddled in my head.
Gain is reduced by 4, then multiplied by .82 from the loading resistor.
So a 1V signal would become 4.5V, then 4.5/4 = 1.125V, times .82 = .92V, so I need a little more gain.
Two questions:
