I'm interested in trying out the "balanced" speaker arrangement Doc has mentioned but have no real need for impedance switching boards, since I've settled the question of what taps to use with my speakers. (4 ohm seems best). I do not understand the wiring of these new OPT's, as they do not appear to be labeled. If I want to make a virtual ground with a 70 ohm resistor going from the center tap of the secondary to ground, which pin represents the center tap? Then, which pins would I take to the speakers for 4 ohms? 8 ohms?
Thanks in advance - I'm sure others have this question as well!
