Bad 2a3? And loose 4-pin sockets...
ZenAudio
So I just had one channel of my Stereomour II lose about 80% of its volume.  Switched the 2a3's (JJ's) and the problem moved to the opposite channel.  Put my Sovtek's back in and everything is back to normal. Assuming this is just a bad tube.  Prior to this, I've noticed that the 4-pin tube sockets are not tight.  Is it possible to manually tighten those?  I believe I saw a post or two on this somewhere, but couldn't find it again after a search.
The same loss of volume on one side happened to me with two different pairs of JJ 2A3-40s. As in your case it followed the tube when switching sides. This makes lose sockets a less likely cause. In my case it was a tube failing both times.
Fortunately, my tubes were still under warranty and replaced for free. Ultimately, I switched to Emission Labs solid plate 2A3s and haven't had any problems for more than 2 years.
Still lust for the EML's true meshies, soundwise and visually.  My concern with the loose sockets is that the Eurotube site mentions loose sockets causing tube failure.
When you mention a loose socket, is it failing to make contact with the tube?
The current 4 pin sockets that we use are a bit flexible, which makes them more gentle on the tubes when inserted, but contact quality is quite good.
Yes, PB, the 2a3's are loose in the 4-pin holes.  Occasionally will have a channel go out and I will adjust the offending tube and sound returns.  Can I use a jeweler's screwdriver to adjust them from the top?
