I'm having difficulty with the B side voltage readings, and the LED connecting B3 and the center terminal. I've replaced that LED, being certain of polarity. It does not glow, even in the dark (powering up a troublesome circuit and then turning off the light was a true hold-your-breath experience!). Aberrant voltage readings are as follows, with expected readings in parentheses:
17: 154 V (0)
18: 152 V (70-90)
19: 152 V (70-90)
20: 152 V (70-90)
21: 70 mV (0)
23: +/- 30 mv (0)
26: 153 V (70-90)
27: +/- 20 mV (0)
28: 132 mV (0)
I've reflowed and desoldered all of the connections on that side of the circuit, and looked closely (with magnifying lens) for miswiring. There was one correction that I needed to make, i.e. clipping the lead of the 10.7K resistor (1072F) at terminal 20L, which had been in contact with the chassis. All voltage readings above were taken after the excess lead was removed.
I am concerned that I may have overheated one of the components, with the desoldering/resoldering activity. Other than that, I am at loggerheads regarding what I have not corrected. Any thoughts? Many thanks.
17: 154 V (0)
18: 152 V (70-90)
19: 152 V (70-90)
20: 152 V (70-90)
21: 70 mV (0)
23: +/- 30 mv (0)
26: 153 V (70-90)
27: +/- 20 mV (0)
28: 132 mV (0)
