Up late on a Friday night, trying to better understand tube amps... Not trying to tweak, just to understand.
On the PSU diagram for the Crack, it shows the rectifier bridge grounded to the PSU ground. Poking with my multimeter, I can see that the neg lead from my rectifier IS grounded to the chassis.
Where is that ground connection? I think it is through the center pin of the terminal strip attached to the 12au7 socket.
If that's the case, is the power supply grounded "through" the headphone jack? Does that matter? I'm fuzzy on ground loops - would it be good or bad to ground terminal 20 straight to chassis earth?
(You guys named it Crack for a reason!)
