IntarsiaGuy2
Hello, just finished a crack build and have audio only coming out the left side.
Below is what I have done:
- Inspected all solder joints. Fixed any that looked at all dubious. Having said that, I have only been soldering a short time and so my inspection skills are probably not the best.
- Went back and reviewed each step. Cap that goes from 6 to 7 was backwards. Fixed that. Did not find any other errors. Could this have caused damage?
- Went through all resister and voltage checks successfully.
- Tried it and only get output from the left side. NOTE: when I swap RCA cables, I still only get audio from the left. This eliminates the RCA connectors and cables.
- tried a different pair of headphones with no difference
Would appreciate advice on specific things to look for since my general inspection did not resolve the issue.
Thanks, Scott
Thanks, Scott
