Here are the readings of my resistance check:
Terminal --- Resistance Reading
T1---1.4-1.3...1.1M ohms...
T2---2.7-2.6...2.4M ohms...
T3---0 ohms
T4---5.0-4.9...4.0M ohms...
T5---55-56-57---60K ohms...
T6---2.48K
T7---2.93K
T8---0 ohms
T9---2.92K
T10--2.48K
T12--0 ohms
T13--280-270-260K ohms...
T14--0 ohms
T20--0 ohms
T22--stayed at the initial reading of 1 (the reading when multimeter is set to resistance check). Then I found there is a fiber washer between T22 and the plate. So I think the reading of T22 can never be zero ohm. The zero ohm for T22 from the manual is more likely an error, I believe.
B3---2.93K ohms
B6---2.92K ohms
RCA jacks:
Ground---0 ohm
Center Pins---101K ohms for red jack, and 106K ohms for black jack
I'd really appreciate it if someone could help me confirm:
1. whether the zero ohm for Terminal 22 from the manual is not correct?
2. whether the rest of my resistance readings are OK?
T3---0 ohms
T6---2.48K
T7---2.93K
T8---0 ohms
T9---2.92K
T10--2.48K
T12--0 ohms
T14--0 ohms
T20--0 ohms
B3---2.93K ohms
B6---2.92K ohms
RCA jacks:
Ground---0 ohm
