I finished my BeePre build today and it hums
The hum is on both channel, and does not change with the volume or balance pot. All resistance and voltage readings are in acceptable 10% range, with a voltage rate of 227V. The BeePre and the amp are plugged in the same power strip. This is a completely stock build. There is music at the output, so at least the BeePre does what it's supposed to do.
I note that the readings of A2/B2 and A3/B3 are in reversed of the ones in the manual and thought that it's just a typo.
I tried swapping tubes, reflowing most of the solders with no luck. What should I do next? Help!
