Hey, i added the Valab Poti and Neutrik Headphone Jack, but not yet finished because i'm missing some parts.
Have some questions:
1) For the twisted wire from the RCA plugs to the poti, can i use something like 3 or 4 core shielded microphone cable instead?
2) Can i just use any resistors for the headphone jack, desoldering those i accidentally broke the solid wire attached to one of them. Will have to order some.
3) Does my wiring look fine for the poti so far? I also replaced the cables on the small speedball pcb with thicker wires, accidentally used a red one instead of a white one on one side, but it should be correctly wired. Also i extended two of the ground cables at the poti, they were too annoying to replace. I just made a knot, soldered them, and put over some heatshrink. Resistance measures 0, so seems fine. Ignore the screw and other debris on the pictures, i removed those
For the missing resistor, in the manual it says 2.49k, but i can only find 2.4k at my most convenient online shop.
Would that work too? I can go to 2.7k instead, but nothing inbetween it seems. Alternative i could add a 2.4k and a 91ohm resistor.
https://www.conrad.de/de/kohleschicht-widerstand-24-k-axial-bedrahtet-025-w-panasonic-erd-s2tj243v-1-st-1471374.html
https://www.conrad.de/de/kohleschicht-widerstand-91-axial-bedrahtet-025-w-panasonic-erd-s2tj910v-1-st-1473137.html
Images:
http://imgur.com/a/Qvaza
Images:
