AC Voltage [resolved]
El Tel
Hi Everyone
Just started the first part of the wiring and the first check, (the AC power line Voltage) and the reading from the multi meter is 258 volts !
Is this ok ? Bit worried, as it says in the manual that i should next wire the power transformer a certain way if the reading is greater than 235V
and less than 245V. UK Voltage.
Thanks Guys
Wow, 258 is quite high.  I would definitely suggest contacting your power utility and letting them know and request a service appointment to get that addressed.
You can wire the amp for 240V mains and things will be a bit high, but the amp will still work.  If your power company isn't able to knock down your incoming voltage, let us know and I may be able to provide some other strategies for knocking things down a bit.
HI Paul
It is a bit strange as when i did the Moreplay build just a few months ago the reading was 234V.
Thanks for the info buddy !
Terry
I've spent more time than I'd like to admit chasing strange problems that ended up being dead meter batteries giving me bad information.
Morning Paul
You were SPOT ON with your call about the battery being low, I recharged it and now the AC is reading 229V 😁
Thank you once again for your help and sharing your knowledge !!!
