Doc B. said:No progress, we are still flogging the active step up idea, which is turning out to be quite a challenge.
Pfenning said:snip...On the motor, how do I regulate the speed to dial it in? I can calculate the idler diameter, and build it (i think) to a high precision diameter, but how do I make slight adjustments in the speed to get it exact? How close will the motor run to the specified rpm? There has to be some tolerance on that, but how much?
Pfenning
Pfenning said:Ok, so I understand the motor speed is set based off the 60 hertz. How do I build a speed controller like you and Geary mention? I follow you on the torque reduction idea. Can I rob the design from an existing TT (TD124 or ???)? I'm confident in my ability to build the mechanical items, but I'm pretty lost on the motor controller stuff. I need a pretty clear path to follow.
Pfenning
We use essential cookies to make this site work, and optional cookies to enhance your experience.
