ritchiepurple
After installing the speedball upgrade I cant seem to get the amp to work. The A3 LED no longer lights up and the back half of the 12AU7 doesn't seem to light up. I have tried re-soldering points A1-A5 and I have re-soldered my way through the other points in the channel but voltage readings haven't changed (see readings below, my readings in the brackets).
Terminal
1 75 (85)
2 170 (185)
3 0 (0)
4 170 (184)
5 75 (170)
6 0 (0)
7 100 (95)
8 0 (0)
9 100 (176)
10 0 (0)
11 0 (0)
12 0 (0)
13 170 (185)
14 0 (0)
15 185 (203)
19 0 (84)
20 206 (0)
A1 75 (175)
A2 0 (0)
A3 1.56 (14)
A4 0 (0)
A5 0 (0)
A6 75 (85)
A7 0 (0)
A8 1.56 (1)
A9 0 (0)
B1 5 (84)
B2 170 (184)
B3 100 (95)
B4 75 (176)
B5 170 (182)
B6 100 (175)
B7 0 (0)
B8 0 (0)
I hadn't used the amp in a while before i did the upgrade so there may be more than one issue. Any ideas?
Thanks in advance!
Terminal
1 75 (85)
2 170 (185)
3 0 (0)
4 170 (184)
5 75 (170)
6 0 (0)
7 100 (95)
8 0 (0)
9 100 (176)
10 0 (0)
11 0 (0)
12 0 (0)
13 170 (185)
14 0 (0)
15 185 (203)
19 0 (84)
20 206 (0)
A1 75 (175)
A2 0 (0)
A3 1.56 (14)
A4 0 (0)
A5 0 (0)
A6 75 (85)
A7 0 (0)
A8 1.56 (1)
A9 0 (0)
B1 5 (84)
B2 170 (184)
B3 100 (95)
B4 75 (176)
B5 170 (182)
B6 100 (175)
B7 0 (0)
B8 0 (0)
Thanks in advance!
