galyons
I am buying a pair of original Paramounts w/300B's. I will need to rework them because the original build was poorly done and the cosmetics are more than tired.
PJ mentioned several times in the old and new forums that his plan was to take the drivers to 6SN7's on his. That would be my preference as well. But I could not find any needed circuit changes for the original 12AT7 driver boards in my forum searches.
I also plan to implement the B+ switch on the PS board, (switch on the exterior), as described on the forum by PJ:
“For the stock Paramount in 2A3 configuration (direct coupled), we have seen no problems with old stock 2A3s, or with the supplied Sovtek tubes. A few modern-production tubes have shown a visible and/or audible arc and "pop" through the speakers; this has been known since the ParaGlow days (predecessor to the 2A3 Paramount) and the usual solution was to implement a standby switch on the high voltage supply - or use a tube that does not have the problem. This is, incidentally, why the Paramount power supply circuit board has a place for that high-voltage switch - it's not mentioned in the manual where a jumper closes the circuit, but the jumper is in the circuit at a place where a normal 240vAC switch can be safely used to switch on the high voltage.â€
My reading of the information on the softstart V1.1 upgrade is that it is primarily to accommodate 2A3's being directly coupled and the 5760 driver. (I like the 5760 and have them in a non-BH headphone amp, but have too many 6SN7 & 7N7 tubes to not use them!)
So the change to octal/loktal and the B+ switch should get me everything that I want/need. (I have Paramour 45's w/ MQ iron and Paramour 2A3's with Altec OPT's, (yeah I know, maybe a couple too many P's!)) If I decide to give up the 300B’s down the road for 2A3’s, then I would definitely do the soft start, but maybe leave the driver as a 6SN7 or 7N7.
PJ said to post so the information would be available to the forum. His initial response was:
“ The pinout of the 6SN7 is obviously different :^) but other than that the SS board should work. You'll be adjusting for something around 6 volts bias on the driver section instead of 4v on the 5670, but the range is 2.5 to 7.5 volts so there should be no problem.
I do definitely recommend the SS board for any direct coupled version, 2A3 or 45. The ability to adjust the driver plate voltage is very important to get the best out of the design, and was left out of the original Paramount only because it repeated the legacy (Afterglow/Paraglow) design as closely as possible.
I haven't done it myself yet, so no direct experience. But I'll help out on the forum.â€
The old driver boards for the 12AT7 don't have a trim pot, but it looks like the current requirements are close for the 6SN7, as well. Will there need to be resistor or other changes to the old boards to make them work with 6SN7's?
I will start the rehab on the amps early next week. Will need a few days to get them running to original spec's with the 12AT7's. Then switch out the 9 pin socket for an 8 and let the games begin!
Geary
Geary
