I managed to snag a pair of NOS Type-45 tubes from the 30's or 40's (Slivertone brand, ST shape) for just $60 and made the few circuit changes to my new Stereomour to see what all the buzz was about. They sound great! The 45's have zero hum on my amp, even over headphones wired to the speaker terminals to assist in performing hum cancellation (as my ancient, cheap multimeter does not go low enough). When plugging the Sovteks back in, the sound got harder, the soundstage more forward, and the bass less dynamic. The 45's seem to do everything the 2A3's do, but better. Also, the lower output power is not a problem in an urban condo with wood floors
This does lead to a question: the Rp on the 2A3 is 800 ohm, and the 45's are somewhere around 1800 ohm. Since the primary resistance of the output transformers is not changed between tube types (e.g., remains at 4k) and therefore maintains the same step-down ratio, would not the secondary impedance at the speaker terminal be double that of the 2A3 for a given tap? (So, 8 ohms becomes 16, etc). I ask this because my Klipsch speakers seem to be more like 5 ohms versus 8, and sound very congested and bloated unless using a lower impedance tap than 8 ohms. I originally wired the 2a3 version of my Stereomour for 2 ohm outputs, as to obtain the best damping factor.
