Hi, fellow Bottlehead users and moderators. My name is Kevin, I'm posting this here because I'm a big fan of tubes and I have a nice 45/2a3 SET amp custom made from a highly respected German designer. I was wondering if anyone very knowledgeable with tube circuits and transformers can clear this up for me.
Basically my amp has speaker taps for 4, 8, 16 ohm. However the designer told me that this is only for 2a3 tube. When I'm using 45 tubes ( switch activated), he told me the speaker taps become 8, 16, 32 ohm due to the 45 having double the plate resistance of the 2a3. My amp power supply has also been modified by the designer to also be able to use 46 tube ( w/ tube adaptor).
My output transformer are from Tango ( XE-20S) which has primaries of 2.5k, 3.5k, 5k activated depending on which secondaries are hooked up.
Following up above on the relative impedance difference of the 46 tubes compared to the 2a3, the speaker taps would therefore be roughly 12, 24, 48 ohms when 46 tube is used.
Since my speakers are 16 ohms, can anyone confirm for me if the 46 tube is properly loaded on my amp when I'm using the 12 ohm reflected speaker tap ? Thank you very much in advance.
Kevin
Kevin
