22.1k resistor replacement
shimacm
Good morning everybody!
I need your help.
I removed the Speedball kit, and am reinstalling the standard model coils.
But I can't resolder the 22.1k resistance because the wire was cut very close to the resistance.
In my city I only found the resistance of 22k, 1W, 10% tolerance.
The colors are (red, red, orange and gold).
My question is whether this resistance is a good substitute.
My other question is in which position should I solder it in the circuit.
Thanks.
That resistor will work to replace what we provided.  I'm not sure about your other question, as you would simply put them back where the manual instructs you to.
If you mean how to orient the the direction of the color bands on the resistor--either red, red, orange, gold or gold, orange, red, red--it doesn't matter.
I installed the resistors and it worked.
Testing the amplifier I'm feeling an excess of saturation in the bass.
Does the 22k resistance switch have anything to do with this?
I use ZMF Veritè and HD650 on it.
I redid the resistor and voltage tests and wrote down the results to see if that helps.
Resistor Test:
1 - random from 40 to 70
2 - random from 40 to 70
3 - 0
4 - random from 40 to 70
5 - random from 70 to 120.
6 - 0
7 - 2.9
8 - 0
9 - 2.9
10 - 0
12 - 0
13 - random from 40 and up
14 - 0
20 - 0
22 - 0
B3 - 2.9
B6 - 2.9
Red RCA pin - 90
Black RCA pin - 88
Earth RCA - 0
Voltage Test:
1 - 59.6
2 - 190.4
3 - 0
4 - 191.3
5 - 57.1
6 - 0
7 - 99.5
8 - 0
9 - 98.2
10 - 0
I would like to add to my previous comment the following:
With a little more listening time, I realized that saturation affects all frequency ranges when the volume is increased, that is, the sound distorts at higher volumes.
I installed a 6sn7 socket in place of the traditional 12au7.
Wiring from the volume pot to the RCA jacks is 1.5mm stiff wire. (I had to adapt, because I'm going to install two 8-pin sockets to use 6j5g and I had to lengthen the wiring that goes from the volume pot to the RCA connectors, because I'm going to install two film output caps and I'm going to run the wiring over the caps). The thread that comes with the Kit was insufficient for these changes and in my country I can't find similar thread.
I'll post some pictures of the assembly.
More
I'm sorry for the extra posts to add more photos, but I just now found the option to attach more than one photo in the same post.
If I shouldn't connect pins 3 and 6 to ground, how should I connect them then?
In socket 12ua7, there is a central pin to which the ground is connected, and from it, LEDs are connected to pins 3 and 8.
But socket 6sn7 does not have this central pin.
How to proceed then?
