2wo
Active member
Next would be to get the C4S for the driver working. The SS is set for 4.3ma, which is probably OK for now. Refer to the SR-45 schematic you can connect a 160k from bD to ground and remove the 300k RLd.
Now, from previous testing it look like the C4S was passing all the B+. This does not bode well for the active components. you can test the LEDs with your meter or a battery, if they light they're OK.
You can test the C4S. leave the 47K in series, Connected from pin 6 to OB and restore the B+ to IB.
If the C4S is working the voltage ACROSS the 47k will only be be a couple of volts. if not replace the transistors and LEDs and try again...John
edit, check the voltage across the 47K before you make changes, so you know were you start
