Brooklynbottle
Just completed my Eros 2 build and ran through the resistance and voltage checks. Everything within spec except for 1A & 1B reading 100v.
I read through the forum and noted Paul's advice to look more closely at the regulator board (near Au7) and took the following readings:
OA/B 220v
AKREG 7.09
BKREG 7.06
A/B bregs 0
I examined my wiring and solders all look to be up to snuff.
Obviously something is up w/ the BREG voltage.
Many thanks in advance for guidance.
Addendum:
Is it possible that I fried my 431's? I accidentally installed the 220 ohm instead of the 220k ohm and powered up as recommended before I spotted the error and replaced w/ the correct resistor.
OA/B 220v
AKREG 7.09
BKREG 7.06
A/B bregs 0
Addendum:
