120V to 220V higher readings, 2nd problem noticeable hum both channels
Jimb0
Member
I assembled a S3X with C4S upgrade wired for 120V. All voltages checked out fine. However, when I modified it for 220V I am getting higher readings. I assume the voltages would be cut in half but a few of the terminals are now reading higher. Other terminals seem to be ok. Using 120V AC line voltage
2 is reading ~250V
OA and OB are reading ~250V
I resoldered all the wiring on the main transformer but still got the same readings
These issues are not from your rewiring of the power transformer wiring unless you have many, many other voltages that are all out of whack.
What are you getting a terminals 3/17?
Can you carefully measure the DC voltage at pin 9 on each tube?
It could also help if you posted photos of the build if the problem is not immediately apparent.
I rewired it back to 120v to retest the voltages. Everything checked out normal. Wired to 120V, pin 9 read 2 or 3 volts
That's in the 120V configuration. I'm going to try the 220V configuration today and check it again and post my readings
Tested it on the 220v configuration again.
2  243v
3  3v
4  0v
5  0v
6  249v
7  263v
10 260v
Pin 9 A/B  2v
16  159v
17  4v
18  0v
19  0v
20  241v
21  261v
24  257v
H2, H5  +2v
H4, H7  -2v
I built this for a customer who lives in the UK and don't have a step-up transformer to test it. I could get one if that's what I really need but I thought the voltages would come out lower not higher on some of the readings
Yes, you need to use a step-up transformer to test the amp once you've wired it for 220V.  Without adequate heater voltage, the tubes won't conduct, so most of the voltage readings are pretty meaningless.
I was able to test it on the step-up transformer and everything checked out fine. Thanks for the help as always Paul!
Hi Paul. I did not do a listening test on the 220v until now. I'm getting a hum on both channels. I was not getting a hum on the 120v configuration. Any thoughts why this is happening?
I'm using a Seyas 120v to 220v 500w step up converter. Source is a Schiit Modi Multibit hooked up to my desktop
