Toby's Stereomour
Excellent!
I like the larger base/top plate.  This amp has a nice balance to the layout.
What do you plan for the base?
Grainger49 said:
Excellent!
Hi Granger,
Somehow I missed your post. I found it as I was posting my finished base. I rounded the top outer edge with a 1/4 router bit and sanded with 100 then 150 grit. I then used the Minwax Polyurethane gloss with a bristle brush. For the base coat I used enough to soak the wood without allowing any runs. After that dried I used 220 grit, then another coat of Minwax, then 320 grit and a final coat. I really like the product. The attached picture is not the best, but gives a good idea of the surface. I also used this Minwax on a set of MLTL cabinets over African Ribbon Mahogany veneer.
