pvannest
Member
I just completed my mainline and have a few issues. Note, this is my 4th kit.
First off the resistance I get from 12, 14, 17, 24, 27, 29 are all nothing. Not one of them is really connected to anything let alone any form of capacitor. The rest of the resistance checks are in parameters.
On the voltage side of things, I have the following.
+275 vDC, I have 265
+6.3 vDC, I have 5.6, not anywhere near 55-65 Volts
-6.3 vDC, On the left I am reading, 5.9 Volts DC on the left side and I am reading. .65 Volts on the left. I will be resoldering both of the leads from the power supply and see what happens there.
IA on the A side C4S board is reading 217,4 volts
IA on the B side C4S board is reading 265 Volts
Breg Regulator both sides is 217.4 and 217.6 respectively
-reg is 0
Kreg Regulator board is 9.7 Volts and 215 on the B side
Note, I was able to adjust the BIAS on one side just fine, the other side is not working. No surprise there. In addition, 2 out of the four leds on one board are not lit. I am going to attempt to resolder that whoe board and hope to find my issues there.
I am most concerned about the resistance checks mentioned above and those tab are not connected to anything to start with.
Any ideas where to start?
-reg is 0
