Hi:
Fired up my system to play some vinyl last night after being gone for a couple of weeks. Other sources (CD, Streamer) fine so suspected it was my Reduction phono preamp.
Tried swapping tubes but no change, so not a bad tube. Also swapped out to a diff turntable and cables to eliminate that variable. Finally, I also put a different phono preamp into the system and all worked. So seems to be the Reduction based on all that.
Took a look on the workbench and cannot find any obvious bad solder joints or loose wires...so I'm at a loss as to how to proceed. My electrical knowledge is scant...I can follow directions and solder and use multi-meter...so love building the kits but beyond that I'm limited... :-\
Would really appreciate some tech support help...
Regards,
Chuck
p.s. My kit has the added Integration upgrade...
Regards,
Chuck
