You can set your meter to DC voltage and measure the voltage between pins 1 and 12 on the offending side to check the heater voltage. It should be about 6.3V, but it would have to be a lot lower than that to see reduced emission (I'd expect ~5.7V or so and you might encounter a problem).
If you swapped tubes and the issue stayed on one side, then you'll want to reflow your solder joints and poke around to look for loose connections.
You need to measure the DC voltage between pins 1 and 12 on the offending tube socket and report that DC voltage, not the voltage on "pads".Edit: When both tubes are connected, DC pads show 2.9V.
With one tube attached, other is ~6.7V. I checked in both sockets, they are more or less the same.You need to measure the DC voltage between pins 1 and 12 on the offending tube socket and report that DC voltage, not the voltage on "pads".
Both are 5.8V with both tubes installed.Both sockets are 6.7V with both tubes in both sockets?
You need to check the DC voltage between pins 1 and 12 on both sockets with both tubes installed to be sure both of those DC voltages are the same (these are the voltages that make the tubes glow, and this will either confirm that your observed difference in brightness matters, or it will tell us that there's nothing significant to that observation).
We use essential cookies to make this site work, and optional cookies to enhance your experience.
