My first ever electronic build. Once I'd completed a couple of soldered joints I was away. Took my time over five or six afternoons for the plinth (first) and then plucked up the courage for the electronics. Pretty straight forward once I was organised. Lots of inspiration from Bottlehead, YouTube and the web. Slight concern over the final voltage check (UK 240V) but it turned out ok thanks to PB. Only issue is the on/off switch which has gone flimsy and is stuck on for some reason (a replacement is on it's way). Next up is Speedball but the PCB soldering does look fiddley.
cheers_dave
cheers_dave
