Hello all, I just completed the final voltage check....IA 220.3v, IB 220.3v, OA 158.5v, OB 128.2v OC 97.3v, OD 60.3v, OKA 98.5v, OKB 62.2v, OKC 1.512v, OKD 0v. LED D1B not lit. I read thru the previous posts regarding this and reflowed all the solder joints from top of the C4S board. I then checked the tube sockets C1,C2,C7,A6,B6,B9 and A9 for the correct 90.9 90R9F ohm resistor and all checked to spec. OB,OD,OKB and OKD all failed and are on the R side of C4S board as you look down......Is this coincidence that they all are on the right side of the board? Im unsure of what to check and or test next, any help would be appreciated. Regards, Jack
