Crack Two: Officially Hooked
Evan
I think I can say I am hooked on building audio gear. Though I'm probably due to take a break now.
Just wrapped up my second Crack build. I wanted to experiment with parts and capacitors this time, so I ordered a PT-7 power transformer and top plate from Bottlehead and then sourced the rest of the parts myself. I used bare OCC wire I insulated myself, Ruby Gold electrolytic caps on the power supply bypassed with Jantzen Standard-Z caps, Jantzen Cross-Caps for the outputs, all Vishay resistors, and an Alps Blue Velvet pot. I also used a pair of bakelite tube sockets that use pins instead of lugs. While the pins on the nine-pin socket are tiny and closely spaced it wasn't as hard as I was anticipating to wrap the wire around each one. I got the idea for the solder lugs with the capacitors from another builder, that worked very nicely. No room for a Speedball kit though.
A small scare when the resistance values weren't stabilizing and the fuse popped when I powered it up the first time. Set it down for a day. Found I wasn't getting a good connection with the probes, and I was using .5A fast blow fuses.
I made the zebra wood base at the same time as my Stereomour base. On the crack I was able to wrap the grain around the corners of the base. It looks really cool and I like the matching kit.
Disclaimer: I don't recommend building your first kit this way. Doing it this way also made me appreciate just how nice quality the standard parts are that Bottlehead supplies in their kits.
Nice work I love the Zebra wood for the base and gloss black bell housing. How did the Jantzen Standard-Z caps work out for the bypassing? I have really enjoyed building and trying out mods on mine and have been thinking about building another Crack and this is a route I might consider.
I never knew you could buy the transformer and base plate alone, tempting...
Love the zebra wood base, tis very nice!
Thanks guys. I've been really happy with the bases. I'm working on ways to light up the shelf my amps sit on to be able to show them off.
I haven't been able to compare the amps back to back since I pirated the fuse from my first Crack to power the new one. I'll be picking up some more soon so that I can see what kind of difference the caps might have made. The nice thing about the Jantzen bypass caps is that they are quite compact.
If you have built a couple Bottlehead kits, want to experiment, and have a high level of tolerance for "fiddlyness" it is pretty enjoyable sourcing all the components. Careful searches and examinations of dimensional drawings on Mouser are key.
Guys I should explain that we bent the rules a bit for Evan regarding the sale of the parts. This is because Evan is local, knows what he is doing and understood that we can't offer tech support on something that is made from parts other than those we supply. Normally we just sell complete kits.
Evan I like the look of those standoff connectors you have used for your capacitors do you have a link to supplier or part name/No
Cheers
