choosing a choke
bottleheader
Hi folks,
It is recommended to replace the first 270 ohm resistor with the Triad C-7X which is 90mA.
Would the Lundahl LL2743 at 90mA and 50H inductance work (well?) in the Crack?
The choke usually goes in the power supply, where it reduces the (already-inaudible) hum. It is not in the signal path.
Yes it will work, in the sense that it will reduce the hum even more than a 10H choke would.
DCR of the C7-X is 270 ohms, same as the resistor it replaces. So B+ will not change. Looks like the LL2743 wired in series would have a DCR of 400 ohms. So you will potentially (yes a bad joke) be seeing about 9-10V less B+ assuming around 75mA current. Probably not enough difference to worry about. Fitting it may be more of a challenge as it is a bit bigger than the C7-X. Potential for audible benefit (less PS ripple) could probably be modeled in SPICE before you spend the coin. It is roughly 10X as expensive as the C7-X. If you get 10X better performance from the LL2743 it would certainly be worth sharing your result here.
