Thanks. Here's my problem...I've recently bought a ton of tools for this project:
- a drill press
- a set of 5 stepped unibits
- a set of titanium drill bits
- a set of GreenLee hole cutters for metal
- a Proxxon rotary tool
- the Proxxon Flexishaft
- a set of cut-off wheels
- a set of Dremel engraving bits,
- a foot switch (for the Proxxon and drill press)
- a scribe
- an automatic center punch
- a deburring tool
- jigsaw blades for metal
- a respirator and filters
- various files
- a file card and brush
- safety goggles
- a heat gun
- screw taps
- a tap wrench
- cutting oil
- etc., etc., etc.
I dont meant that I've acquired these over the past two years -- I mean I've bought them in the last two weeks or so. Most of these I justified by saying that I would use them again in the future. But I doubt I will ever have to drill holes in wood over 1/2" again, so I am trying to avoid spending a lot of money on a nice bit that I will use to drill 8 holes and then never use again.
With that background, if you had to drill roughly 1" holes in wood that was not particularly hard and roughly 1/2" to 3/4" thick, would I be better off with a cheap hole saw, a cheap jumbo drill bit off eBay (these don't seem to get good reviews, but some people seem to be trying them on metal), or a spade bit? I can always clean up the hole after drilling it by using the Proxxon or the deburring tool...
Best regards,
Adam
- a drill press
- a scribe
- a deburring tool
- various files
- safety goggles
- a heat gun
- screw taps
- a tap wrench
- cutting oil
- etc., etc., etc.
Best regards,
Adam
