rickdagless
So I just finished up the Mainline build (Woohoo!) and all of the resistances and voltages checked out. (Quick question: for the fourth voltage reading, is it meant to say "IA on the C side C4S board"?)
I'm adjusting the potentiometers and I'm very fascinated with getting each of the readings to be 145VDC on the dot, so I'm letting the Mainline run and "burn in" as the voltage seems to reach its lower limit. While I'm sure I'm close enough at this point, I just can't help myself -- is there a reason I shouldn't be doing this?
I haven't been able to listen to it yet as I'm waiting for some connectors in the mail, so till then I guess I'm keeping myself occupied with this fine tuning.
