howardnair
this is my daughters-similar chassis-light mahogany dyed with yellow pigment which will tone down and is not as yellow as the pics show-cocobolo knobs-the shadow lines painted red-- changed my old trannie cover to copper face with bloodwood and am using the round one on the new one-the pics of the underside that are yellow or blond are the latest project-sorry everything is scattered had some upload problems--the actual kit will arrive sep1-what you see are jupiter .1 uf for the coupling caps and mundorf rxf-oil 3.3 uf with a sonic cap teflon .047 paralleled for the parafeed caps
the large caps in the center are the cathode bypass caps they are mundorf tube-cap 47uf -a alps volume control and a goldpoint selector and a rotary on/off switch-IAG boards for the 2a3 and 12at7-the large washer things are just that-washers let into the top which are brackets for the hum pots-the tubes will be the sophia electric bakelite 2A3's and a mullard cv4024
https://picasaweb.google.com/100635555508988591604/DropBox?authkey=Gv1sRgCP-tj9DHhb7HggE#
