Another Crack - must be breeding like Rabbits!!
ALL212
Member
Crack #2.  This one is 100% stock.  Once it's broke in I'll compare it to my not-so-stock crack and see if I can locate the magic that happened when the original got the power supply upgraded.
Straight out of the shop and stock it sounds so nice.  Doc and the gang - you do good work!!
I think I'll put any further comments on these over in the Crack area.
However...
Stock is nice - really, it is.  Modded is better, bass is easily noticed as a distinct improvement.
Speedball added and instead of blowing some big bucks on 100uf caps I used a pair of 100uf 450v Nichicon's and tipped 'em with 1.5uf solens.  Added a small film cap to the last electrolytic in the power supply also.  These things are so sweet....
Just prior to adding the speedball.
Final under the hood view.
