JamieMcC
Active member
After fitting some film caps and a Triad choke to the Crack I needed a bit more ground clearance and had a bit of a idea to use some wood I had originally glued up to make some headphone stands out of, luckily it was just long enough to make a enclosure out of. The wood enclosure is about 20mm deeper than the standard enclosure. Some rubber door stops for feet allow plenty of air to circulate.
