RestoredSparda
Howdy. Checking in to see if this is an issue or not.
I've recently noticed a quiet 60hz hum through HD800 and HD650 on mainline. It may have always been there but I have just ignored it or thought it was an appliance.
I've removed all inputs, brought it to a different outlet with no source and the hum is still there. Tightened all screws
It is pretty faint on low gain, but definitely noticeable on high gain. The volume level of hum doesn't change with the attenuator steps. It stays a constant volume. The volume of the hum increases and decreases if single ended or balanced is selected.
Also checking that volume levels are normal. With a 2vrms output from my dac the Mainline is VERY loud if course is on -27 and fine is on -7.5.
I can usually only listen with course on -36 and play around with fine.
Course at -18, -9, and 0 are unlistenable with both HD650 and HD800.
Thanks for any ideas!
